I am preparing to install a 1500watt solar array (6, 250watt panels) to power my 24volt, 2.4Kw Lifepo4 battery system. I am using the AIMS 60amp SCC (SCC60AMPPT) and the 3000watt AIMS Inverter.
I need to establish the size(s) and quantity of inline fuses to purchase for my system. Please advise if you have recommendations on the in-line fuses to purchase.
Is it as simple as getting the fuse sized for the SCC rating (ie. 60amp)?
NOTE: I started researching and noted that 100amp in-line fuses are intended for systems with 2500watt inverters or smaller. Is 100amp in-line fuse appropriate?
Also, how many fuses do I need to put in my system other than between the SCC and battery? Add between battery and inverter? Between solar array and SCC? Just put on the (+) wire? Both (+) and (-)?
The six, 250watt panels will be setup in two serial strings of three panels connected in parallel (3 panels per parallel string).
Specs for each panel:
maximum power 270w
Open-circuit Voltage 44.4
voltage at Pmax 35.5
Short-Circuit Current 8.25amps
Current at Pmax 7.6amps
max System Voltage 600
Fuse Rating 15amps
I found this whitepaper on the Renogy site. Is it correct guidance? https://www.renogy.com/blog/how-to-fuse-your-solar-system/
maximum power 270w
Fuse Rating 15amps
