BigGun
A123 cells are not your normal cells, + and - are reversed, the whole body of the cell is the +. Also if you're talking about the packs they have for sale, they're a bitch to get the nickel off and sometimes it makes holes in the cells when they come off. The ones I've fooled with, I just clipped the nickel as close as possible, then spot welded to the old nickel.
Good luck rebuilding a pack of that size with all the cells folded together . The possibility of shorting cells out is very high. It's time consuming just to rebuild a Ryobi 40v pack built in this manner.
I'm kind of gathering that you don't even have the understanding how these cells are put together in series to even test them. Going to be hard to rebuild a pack without that knowledge. Then there's the #1 Issue, does the BMS even function any more, Would be a shame to rebuild the battery to find out the unit isn't functional.
Usually when I rebuild ( lets say a 40v pack ) I charge the old cells up together monitoring closely. The ones that lag behind I charge separately. When I get the voltages high enough, if the pack / bms function , I rebuild it. Others I toss
