Wolfpack7483
I have a "runner cell" in each of my 2 Eco-Worthy server rack batteries (V1 & V2), as well as in my Vatrer, so I thought I'd give the Neey a shot. I installed alligator clips on all the leads, and hooked it up to my V1 EW battery. I double checked voltages and lead placement and everything seems good to go. No matter what I do, I immediately get the flashing red light, just after the blue light starts flashing. I sent the following to Neey tech support, but wondered if anyone else has run into the same issue?
"I have connected the 4a active balancer to an Eco-Worthy 16s server rack battery. I downloaded the app to my iPad & enabled the search function. I have verified all connections and voltages are correct (2x). When I connect the wiring harness to the balancer, the blue light starts flashing, there are 4 "beeps" and the red light flashes continuously. An error message pops up with "request device information failure". The device is connected to the Bluetooth on my iPad. I have tried multiple times with the same result. I tried deleting and re-installing the app with no change. I have tried plugging the connector with the B+ cable 1st, and I've tried plugging it in 2nd, with no change in results."
