I am trying to complete the utility (SCE in California) Net-metering application. This will be a self-install project.
Has anyone completed the application themselves? There are no resources online for completing the application. The only questions I have left are below. I beleive they want information on the inverter since I will not have a generator attached, and they do call the entire system an "Generating Facility" . The only peice of data I could find was the software version # of the inverter from the manufacturer website. But I don't know if any of these others only apply to a generator or to the inverter. These also do not appear to be ratings that appear on a nameplate, but rather they are calculated. I have attached the spec sheet for the inverters (2) and the solar panels (Q-cell 395) if anyone can help.
Does the Generating Facility meet any of the criteria below?
Yes
NOTE: Information in this section is required, as applicable. Please enter 0 (zero) when not applicable.
Prime Mover Type * ?
Select... Photovoltaic Panels
Generator Software Version Number ?
Inverter Software Version Number ?
MCU-6206
Gross Nameplate Rating (kVA) * ?
Gross DC Nameplate Rating (kW) * ?
Net Nameplate Rating (kW) * ?
Operating Voltage (kV) * ?
Power Factor (PF) Rating (%) * ?
Maximum PF Adjustment Range (%) * ?
Minimum PF Adjustment Range (%) * ?
Wiring Configuration * ?
Select... Single-Phase
Short Circuit Current Produced by Generator (Amps) * ?
Generator Design * ?
Select... Synchronous Induction Inverter
Additional Technical Information for Generator / Inverter |
Yes
- Sized larger than 10 kW
- Utilize a technology other than wind, solar or fuel cells that use renewable fuels
- Have a point on interconnection on line side tap
- Require net generation output (NGO) metering
- Have additional generation on-site (including energy storage devices)
- Utilize non-certified equipment
MCU-6206
