K W
Electro-Mechanical Repair & Fabrication
- Nov 27, 2019
- 18
From observation, my utility here in SE MI is very difficult to deal with when it comes to grid-tie home solar. I would prefer not to have to deal with them and am considering a net-zero grid-tie system. Grid-tie only for line synchronization while managing my production to never feed the grid.
My question concerns asymmetrical loads. 240vac and common come into my home and 120vac is available between either side of the 240vac to common, as is the case with most homes in the US. Now, if I'm consuming 1KW at 120vac can I feed 1KW at 240vac back into the my CB panel and have the smart meter on the side of my home register 0 watts consumed?
Since the utility meter has four connectors (2 IN & 2 OUT) I assume that there are current transformers on both side of the 240vac coming in. I've heard rumors that my meter doesn't care about current direction, so you are charged for consumed power and exported power as though it were all consumption. Hence, the meter would see my symmetrical outgoing power used to balance my asymmetrical 1KW load, right? And potentially charge me for it, if the meter is set up that way. Yet, on the utilities HV side of the pole-pig (pole transformer), the utility really doesn't see the asymmetry, seeing only net-zero.
So for true net-zero, not utilizing any equipment that belongs to the utility, it seems I'd need a big (I have 200A service) 1 to 1 transformer with a center taped 420vac winding on the house side and the 240vac winding connected to utilities smart meter. The utility meter would never see any asymmetry that way... An autotransformer would work too, I think.
Am I on target here? Comments?
