Hi. I want to apology in advance for convoluted text ahead, TLDR further below, but I don't know how to explain it more neatly and it is regarding something a certified electrician should do not an average Joe. I'm aware of the fire hazards and personal hazard of high voltage
Can I bond neutral and ground inside an Epever inverter? I used to have neutral and ground bonded in my caravans service panel and that worked great when I ran my caravans 230volt system from the inverter. I was able to trip the ground fault device or RCD by trying to run appliances from ground and line but...
when i disconnected my inverter and connected household ac to my caravan fuses in my house popped. What happend was my house neutral and ground are also bonded and I had a 50/50 shot of plugging in mains ac outlet the right way up (europen ac plug)... basically what happened was mains line and neutral shorted via ground lol. If i plug the ac outlet in upside down that means ground is bonded to neutral in house panel and in caravan panel ground is bonded to line. Costed me 3 fuses before i realized wtf was going on
Therefor since i use 2 different sources of 230v, inverter and main house hold I cant bond neutral to ground in my caravans service panel. That introduced another issue.. I cant get my RCD to trip running off my inverter anymore. RCD tripping works fine when running of house holds ac though.
I have made sure it is impossible for my inverters ac out and any household ac out to be connected at same time to my caravans ac in. My caravans AC in is a plug I have to choose to plug in EITHER to inverter or to a house hold ac out. Idiot proof =)
TLDR
I can safely bond neutral to ground inside the Epever inverter right? Also.. it doesnt matter if i bond "neutral" or "line" to ground inside inverter right? I mean both are the same and whatever I choose to bond to ground is going to be called "neutral" from then on?
TLDR END
On a side note..not sure what significance it has with anything but as the inverter is now unbonded with floating ground..the potential between ground and first line is around 65v and the potential between other line and ground is around 165v. Would it make a difference if i bond the lower or higher voltage to ground making it the neutral?
TLDR
TLDR END
