fabieville
Where do you run the neutral connection from that goes to the inverter output? Do you run the neutral from the main panel disconnect or do u take the connection from the sub panel? Does it matter where it comes from seeing that its the same neutral in the main box that ties back with the one in the sub panel?
I have a off grid set up with a Main panel, sub panel and a transfer switch. I have 2 hots coming from the grid, sub panel where all my loads are and from the inverter going to my transfer switch but in regards to the inverter neutral connection should i run the neutral from the main panel box or take the connection only from the sub panel?
The neutral and ground bars are tied in the main disconnect box.
Running it from the main panel disconnect would be a shorter run to the inverter than taking it from the sub panel so i would use far less wire.
