teal95
Solar Wizard
Running wiring from my solar setup in the barn to a remote shed. 2 sets of conduit, 1 for AC and one for DC. Metal conduit ~50' across barn, then ~200' in plastic buried across to shed, then into metal conduit in shed to PV panels for DC and Romex for AC. Metal box for both transitions. Not having it inspected but want to follow code, as long as following code is the safe direction.
Should all the grounds be tied together in both metal boxes? A single ground is run through each conduit (DC and AC).
Should all the neutrals be tied together? Since I planned for 2 circuits I have 2 white wires through each section.
I wouldn't be surprised if it code is to keep them separate but this doesn't make a lot of sense as they're each tied together back in the breaker panel. As it's a remote panel ground and neutral are separated and I plan to keep them separated.
