johnskdyvn
- Nov 8, 2021
- 53
I'm almost there ! Thanks to every one of you experts on this site i'm going to start installing most of my solar setup this weekend. I do have a question about using the green bonding screw in my panel though.
I am TOTALLY offgrid. I'll be setting up my Growatt 3000 48v inverter this week. I am NOT going to have an "AC in" connection (only AC out). I will be running my AC out wire to a small 100 amp distribution box. I'll only be running 3-4 lines from it (cabin, shed, chicken coop, and some lighting). As I have NO main panel (just the inverter and the small 6 circuit breaker panel), am i supposed to install the grounding screw into the panel? Most of what i watched says as long as my main panel is neutral ground bonded, then i don't need to do that to my subpanel. That being said, my subpanel is actually the only distribution box i'm using.
I thought i read that the Growatt inverter already had a grounding screw inside of it. If true, would this alleviate the neutral ground bond screw that came with my panel? So far, I have run the ground wire to the distribution box. I'm just unaware of having to use that bonding screw?
Also, as stated before, my cabin is offgrid. i don't believe it has a ground rod to the cabin. I always ran the generator to the cabin to power it. I have read that an outbuilding needs 2 ground rods. Is this true, or can i use just the one i ran the other day?
Thank you all in advance. Your knowledge is helping me learn quite a bit.
Johnny
Johnny
