Welcome to the forum.
22-25A is a pretty heavy load for a 100Ah battery. It will NOT last 4 hours. A 100Ah battery will deliver 5A for 20hr yielding 100Ah. Pull more than 5A, and you reduce the capacity. At over 4X the rated 5A current, you'll likely have about 3 hours available, so it's acting more like a 60-70Ah battery due to you pulling heavier loads than its 20hr rating allows.
This phenomenon is called Peukert's Law.
In order to not damage the battery, you should limit your discharge to 50% of that, so you really only have about 1.5 hours of power.
Do Peukert and 50% discharge limit apply at the same time?
What if I have a 100 Ah battery and discharge at say 50A for one hour, at which point it is 100% discharged (low voltage cutout) according to Peukert.
Then I stop draining it and let it sit. Is it now just 50% discharged, and acceptable SoC for reasonable cycle life?
To the extent the reduced available Ah at high current is due to simple IR drop causing reduced voltage output, obviously the chemistry is unaffected. But maybe there is something in chemicals and ion transport also occurring that I don't know about.
How could a norm cheat? This is the official reference for solar batteries. Cranking batteries are rated at C/20.Cheater cheater punkin eater.
Just to get an idea: how heavy is your "100Ah" battery?Deep cycle, a friend recommended the brand and said they're decent
I'd say 30-35kg as far as I remember, I couldn't lift it with one handJust to get an idea: how heavy is your "100Ah" battery?
Battery Voltage at Load test of 25 Amps | 30 min. Return | |||||||
30 min rest | ||||||||
Start | 30 sec | 1 min | 5 min | 10 min | 15 min | 30 min | Recovery | |
12.83 | 11.92 | 11.96 | 12.07 | 12.06 | 12.04 | 11.98 | 12.66 | |
12.82 | 11.96 | 11.99 | 12.11 | 12.11 | 12.10 | 12.05 | 12.68 | |
12.82 | 11.93 | 11.98 | 12.08 | 12.07 | 12.05 | 11.99 | 12.66 | |
12.83 | 11.98 | 12.02 | 12.13 | 12.13 | 12.11 | 12.05 | 12.69 | |
12.80 | 11.95 | 11.99 | 12.10 | 12.10 | 12.09 | 12.03 | 12.67 | |
12.80 | 11.92 | 11.97 | 12.08 | 12.07 | 12.05 | 11.99 | 12.66 | |
12.80 | 11.95 | 12.00 | 12.10 | 12.09 | 12.08 | 12.00 | 12.67 | |
12.80 | 11.95 | 11.99 | 12.10 | 12.09 | 12.07 | 12.00 | 12.67 | |
12.93 | 12.06 | 12.07 | 12.16 | 12.15 | 12.13 | 12.07 | 12.75 | |
12.92 | 12.04 | 12.07 | 12.16 | 12.15 | 12.13 | 12.07 | 12.74 | |
12.96 | 12.09 | 12.08 | 12.18 | 12.17 | 12.15 | 12.09 | 12.78 | |
12.89 | 12.03 | 12.05 | 12.15 | 12.14 | 12.12 | 12.06 | 12.73 | |
12.93 | 12.05 | 12.07 | 12.16 | 12.15 | 12.14 | 12.08 | 12.76 | |
12.94 | 12.07 | 12.09 | 12.19 | 12.18 | 12.16 | 12.11 | 12.78 | |
12.89 | 12.04 | 12.07 | 12.17 | 12.16 | 12.15 | 12.08 | 12.74 | |
12.91 | 12.05 | 12.07 | 12.16 | 12.15 | 12.13 | 12.08 | 12.74 |
Do you know why the voltage drops first and then recovers after 5 mins? I'm just curiousAt 25 amp load, battery terminal voltage will drop to 10.5v in about 2.6 hours. That's about 65 AH of capacity.
If your battery cable voltage drop is too much I can understand inverter cutting out in 90 mins.
At 25 amps battery terminal voltage will drop to 12.0 vdc in about 30 minutes.
Attached is actual data on sixteen different 105 AH lead-acid batteries. This was just a short load time quality check.
Battery Voltage at Load test of 25 Amps 30 min. Return 30 min rest Start 30 sec 1 min 5 min 10 min 15 min 30 min Recovery 12.83 11.92 11.96 12.07 12.06 12.04 11.98 12.66 12.82 11.96 11.99 12.11 12.11 12.10 12.05 12.68 12.82 11.93 11.98 12.08 12.07 12.05 11.99 12.66 12.83 11.98 12.02 12.13 12.13 12.11 12.05 12.69 12.80 11.95 11.99 12.10 12.10 12.09 12.03 12.67 12.80 11.92 11.97 12.08 12.07 12.05 11.99 12.66 12.80 11.95 12.00 12.10 12.09 12.08 12.00 12.67 12.80 11.95 11.99 12.10 12.09 12.07 12.00 12.67 12.93 12.06 12.07 12.16 12.15 12.13 12.07 12.75 12.92 12.04 12.07 12.16 12.15 12.13 12.07 12.74 12.96 12.09 12.08 12.18 12.17 12.15 12.09 12.78 12.89 12.03 12.05 12.15 12.14 12.12 12.06 12.73 12.93 12.05 12.07 12.16 12.15 12.14 12.08 12.76 12.94 12.07 12.09 12.19 12.18 12.16 12.11 12.78 12.89 12.04 12.07 12.17 12.16 12.15 12.08 12.74 12.91 12.05 12.07 12.16 12.15 12.13 12.08 12.74
you just eluded the interesting part of Tariq's question "...and then recovers after 5 mins".V = I * R, voltage = current * resistance.
That is indeed one of the mystery of battery chemistries.
I have the same problem upon trying to measure the battery's internal resistance by calculating the ratio between voltage drops and current increases: that ratio is not constant and changes noticeably when the drop is important, just to recover once the new situation is established.
As a continuous discharge current that would be the appearance. If you stop the current drain periodically, and let it rest to equilibrium, the battery voltage will recover to some degree and there will be some available capacity still left in battery. On my 30 min., 25 amp discharge tests, the battery terminal voltage dropped below 12v but after 30 minutes of no load resting it recovered to near full charge voltage. Actual amount of discharged capacity was about 10%.This is the best write up I've seen for the Puerkert Effect:
Batteries 4 Dummies. The Peukert Lesson - Solar Panels - Solar Panels Forum
Batteries 4 Dummies. The Peukert Lesson In today's lesson we are going to discuss Peukert's Law. Specifically as it applies to Flooded Lead Acid batteries (FLA).www.solarpaneltalk.com
As I interpret this, if you discharge the 100 ah battery at 20 amps, you would only have 60 amps of usable power, so the battery would be at 50% in 1.5 hours.
Battery open circuit 'rested' state voltage | |||||||
Chrg State | Spec Grav 80 deg F | % Acid | Cell Voltage | 6v Battery | 12v Battery | 24v Battery | 48v Battery |
100 | 1.277 | 33.0% | 2.122 | 6.37 | 12.73 | 25.46 | 50.93 |
90 | 1.258 | 30.7% | 2.103 | 6.31 | 12.62 | 25.24 | 50.47 |
80 | 1.238 | 28.3% | 2.083 | 6.25 | 12.50 | 25.00 | 49.99 |
70 | 1.217 | 25.8% | 2.062 | 6.19 | 12.37 | 24.74 | 49.49 |
60 | 1.195 | 23.2% | 2.040 | 6.12 | 12.24 | 24.48 | 48.96 |
50 | 1.172 | 20.5% | 2.017 | 6.05 | 12.10 | 24.20 | 48.41 |
40 | 1.148 | 17.6% | 1.993 | 5.98 | 11.96 | 23.92 | 47.83 |
30 | 1.124 | 14.8% | 1.969 | 5.91 | 11.81 | 23.63 | 47.26 |
20 | 1.098 | 11.7% | 1.943 | 5.83 | 11.66 | 23.32 | 46.63 |
10 | 1.073 | 8.7% | 1.918 | 5.75 | 11.51 | 23.02 | 46.03 |
I'm afraid, you did not catch the question:No mystery at all. Answer is implicit. If a current causes a voltage drop, the removal of said current removes the voltage drop, so the voltage will rise. Same concept applies for charging. Apply a charge current, the voltage will rise. Remove charge current, the voltage will drop.
What are you using for an inverter? I suspect a UPS where you replaced the internal battery.My setup details:
Personal computer consumes 220 watt
LED screen consumes 40 watt
No I'm using a 1000 watts inverterWhat are you using for an inverter? I suspect a UPS where you replaced the internal battery.
Most consumer UPS's will ignore the actual battery voltage and instead use a timer chart based on the AC power draw. You can substitute any larger battery and it will still shutdown at the same time. Leaned this the hard way.
you say 300W i don't think you included the inverter losses so more like 350w to 400w.No I'm using a 1000 watts inverter
