Warranty?My inverter has been not acting as expected. I haven't been able to pull any power from the battery to feed loads. Last night it made a sizzling noise, lights flickered, then a big pop. I expect to blew-up something inside. Its within the 30 day return policy. I think its time for a different option.
Within the 30 day return policy I can't say I blame him for opting to return and get something different. Not that we can be sure it was the fault of the inverter and not something relating to the installation. None of us are there looking at it.Warranty?
It should also have a 5yr warranty enforced by Watts.Within the 30 day return policy I can't say I blame him for opting to return and get something different. Not that we can be sure it was the fault of the inverter and not something relating to the installation. None of us are there looking at it.![]()
Any type of grid tie type merging with limiting will work until it doesn't. There are no guarantees you won't have some feedback onto the grid. If you are absolutely certain you always have 500watts of steady consumption, then you can *maybe* do it. If any of that ever dips down though, the inverter will not react fast enough to avoid exporting onto the grid. The wattage it is offsetting has to be 100% of the time, no exceptions.It should also have a 5yr warranty enforced by Watts.
Scenario ... The nhx resides in the shop. The poco's meter is 50' away between the shop and house. The house is ~100' on the far side of the meter. No net metering agreement.
Could I place the cts' on the nhx's grid connection, set it to something low like 500w export to grid, and have it export some of the excess power to the house without it going to grid? The house should always be pulling considerably more than 500w.
Yes, within the 30 day return option tooWarranty?
Gotta know, was it a hassle free return? Was Watts easy to work with?Yes, within the 30 day return option too
Thanks for the feedback. I am hopeful getting a full refund. I got a crazy good deal on it, being a returned unit that I purchased. But I am right at my 30 return option.Good luck with SGP, be firm with them right away and accept no BS.
1 hour from watts247 is your obvious option.
The version I got wasn’t the watts247. Mine is sunpower gold version. So far they asked a few questions but haven’t authorized a return yet. But I am getting it ready to ship. If I get a full refund. I am looking at the 12kw model. If I can’t find a better deal. Then I will get it from watts247. They are only about an hour or so away. I would just drive down there and get it. I have bought panels and solar assistant orange pi from them.
I am not sure where that information came from, because their webpage clearly states less than 75W Idle consumption per unit15w idle consumption would be absolutely bonkers at this capacity.
Someone has to verify that somehow
I have installed Solar Assistant and Home Assistant. I have both working and talking to each other. Home Assistant see's both systems. Enphase and NHX-10K. Now I need to figure out how to best configure both to save and store as much solar produced power as possible. If anyone knows of anyone who has done some automations in HA for 2 different systems lmk. Here are my Month-to-date stats.
82 kWh Power imported
154.8kWh Produced
125.6kWh Consumed
106.6kWh Exported
from my 6.6k Enphase batteries
19kWh discharged
25.2kWh Charged
My goal is to have the NHX charge and discharge based on solar production from the Enphase. And discharge when solar isn't producing. To reduce exporting and grid power.
I have the NHX "Grid" connected to the Generator breaker in the Enphase System 2. I then have "Loads" connected to the main sub panel as a back feed. Any recommendations on how to proceed using what I have would be appreciated and welcomed. My new battery is a DYI 16s w/314ah box. I have a second on order that will double this.
