Hi!
I have a Ford Transit EL cargo van I'm converting. I just bought two Solaria PowerXT-400R-PM solar panels and am designing my electrical system. Voc at 25C for the panels is 51. I have a Victron 150V/85A controller Victron Energy SmartSolar MPPT Tr VE. Can 150V 85 amp 12/24/36/48-Volt Solar Charge Controller (Bluetooth) and a 12V 300Ah Lithium LiFePO4 battery which has a 200A BMS Ampere Time 12V 300Ah Lithium LiFePO4 Battery, Built-in 200A BMS, Max 2560W Power Output, Easy Installation, 4000+ Deep Cycles, FCC&UL Certificates, 10-Year Lifetime, Perfect for Off-Grid, RV, Solar…
What are the pros and cons of mounting parallel vs series? I understand the voltages would add in series while the amps would add in parallel. I also am aware a series connection is more efficient since the current would be cut in half compared to 2 panels in parallel.
I have read that if I have partial shading, a series wired system could give me an open circuit. Solaria says these panels have "...Sub-strings...interconnected in parallel, within each of the four panel quadrants..." which would perform better in partial shade.
I have also read that having when the sun is low series wired panels are more efficient. The following is from Camper Solar Panels - Series vs Parallel .. "...To charge a 12v battery bank, you’ll need closer to 14 volts (depending on battery chemistry. 14.4 for Lithium) to actually start charging. Most single solar panels in the 100 – 200 watt range have voltages in the 18-20 volt range. If you wire in parallel, this means you’ll only have a range of 6 volts to work with where your solar panel can make power. Basically, this means that your solar panel needs to be operating at 75% capacity before it will even charge your batteries at all. If you wire the same solar panels in series, using the same panels as above, you’ll have about 57 volts to work with. This means that, through the power of the MPPT controller, each panel only needs to be able to muster up 25% of its voltage capacity before it can start making amps in a 3 panel series..."
I plugged in the numbers for my two panels wired in series into the calculator on explorist.life https://www.explorist.life/solar-charge-controller-calculator/ and got 115V max with 9.4A going into the controller and 75A coming out.
It sounds like wiring in series would be the way to go for me. Thoughts? I'd appreciate any feedback related to other issues in my proposed system as well.
Thanks!
Thanks!
