JohnPickett
- Nov 23, 2022
- 16
I am building a new 24v system, because I need 240 VAC to run my well. And I thought that would enable me to run chop saws and compressors we need while we build our house. Ultimately we will be 48 Volt off grid....so I am willing to go there now if needed.
Right now I have the following:
Will this system comfortably run basic carpentry equipment? Chop saws are huge drains. Should I go 48Volt?
This isn't quite finished, I ran neutral from top to bottom on the left side of the board, it looks awesome....in person...not so much photogenic...
Thanks! I have learned all of this from creeping on your boards, and I really appreciate the education. I literally would not be here without this forum.
- 6 300 Watt panels in a 2p3s configuration.
- EPEVER 10415AN Solar Charge Controller - This is not lithium compatible - oh crap!! Change course...
- Midnite Solar Classic 150V 96Amp solar charge controller
- Sigineer Power 3000 Watt 240 VAC inverter.
- 302AH at 24V lithium battery with Overkill Solar 100 Amp BMS
