I have a 16s configuration folded in half to make 2 x 8 cell battery banks. I have built a cabinet that will be screwed into the boat able to take the weight of these two assemblies. Each assembly can be pulled out of the housing for inspection.
If I use a modified bussbar or 8” cable I cannot inspect the banks individually.
Can I connect the two banks with a long cable that will let me pull out one with the other in place? If so what size?
The bms cables will be long enough to allow individual bank inspection.
Each bank is 80lbs
thanks in advance
Each bank is 80lbs
thanks in advance
