Hello all I'm new here just joined today actually. I started reading some of the threads and learned a few but I cannot find the one which I am actively searching for.
I am writing quite long so just see the photo attachments if you want to get to the point. But I'll explain my problem below anyways.
I currently have six 2V 1000AH T-Gel battery (two pairs of negative and positive poles which confuses me sooo much), a 2000W 12V Solar Inverter and a 12V SMPS charger (at 14.01V no load and 13.68V on load)
[This 12V SMPS charger can deliver charge upto 10Amps and at the back of the panel, there is a toggle switch for Lead acid (labelled 15V) and SMF/TUB (labelled 14V) I am currently using on the SMF/TUB mode. On initial charging it charges at around 10A and then gradually drops to around 2 Amps over time]
Each of my 2V cells/batteries have two negative and two positive poles/terminals. And my whole problem revolves around this issue..
I am assuming that ALL of these (terminals) need not necessarily connected???, but as I am scared of damaging the expensive cells, I have actually bolted all the bus bar connections.
And My last confusion comes from the end poles of the batteries (which have been connected in series to output 12V) as they have a double pole. I plugged one pair of the terminal to the charger and the other pair to the inverter. As I am not confident in my setup I have not started actually using it and just left there to charge for 3 hours. After that the top two cells (where the end terminals were connected - to the inverter and the charger) had started to swell a bit. It is just noticeable. So I immediately halted everything and stopped charging.
I feel that each one unit of the 2V cell battery has different compartment inside?? so as to minimize current losses (or other stuff which are advanced for me).
So now I had connected the top end terminal of the batteries of the same polarity together, One pair of the positive of the same cell to itself and the other negative pair of the same cell or vice versa.
I have also included a photo of the battery. Can anyone please help me? I am quite new to 2V batteries and T-Gel/AGM classes of batteries.
Below are captions in the photo attachments:
Initial setup. The two top-most cells are not linked to their like-pole(terminals)
and the crocodile clips are connected to only one pair and the other pair to the inverter. I think this is a mistake?!
Current setup: Now I have connected both of the like-poles using three 4sq.mm copper wires. A small amount of Acidic- Water seems to leak from the central valve structure.
Foot note: Although the leak has ceased now, and occurred only during the charging.
Also - could it be that the new batteries are defective from the manufacturer or do I need some kind of BMS? I am really lost here. Until any further help these batteries are just a 360Kgs or 794pounds of paper-weight. I dare not touch them right now.
Also I am ordering a proper MPPT solar panel module which has been delayed due to COVID issues.
Thank you for your time. I would really appreciate it.
