I have a new LV6548 system installed with a 48V 150AH battery that I built from 16 cells from batteryevo. They were listed as refurbished with a 3 year warranty. They arrived at pretty much the same voltage so I did not do a balance. After seeing the voltages deviate from each other during conservative use I did a top balance on them. I started out with setting my bulk charge at 54.5V and float at 53.1V, trying to be "conservative". The voltages stayed nicely in line with one another. My charge/discharge limits are set at 30A (spec sheet allows up to 50A). The battery seems to be operating fine with these settings, but I am obviously not getting the full use of the battery. So, I changed the settings to more common ones: 56.4V bulk and 54.1V float. The battery charged up to a peak voltage of about 56.8V and settled down to 54.1-54.4V. Then the inverter flipped to discharge mode. Looking at the watchpower app's history the discharge amps peaked at 14A. The battery immediately dropped to 52.6V when it started discharging. It remained discharging for only 22 minutes with amps ranging from 10-14A and then the BMS shut it off. When I checked the battery it was at 52.8V and the individual cells were all within 0.017V of each other. Any idea what happened/is happening? Do I possibly have a bad cell(s) that dropped drastically under load and that's why the BMS shut it down? Is it normal for the pack to immediately drop ~1.5V when starting to discharge (I do not believe so)? The BMS is set to shut down if cell voltage drops below 3.00V or goes above 3.65V or there's a difference in voltage between cells greater than 0.50V. Could a cell(s) have dropped below 3.00V under load and then bounced back after the load was disconnected?
Thanks for any help or guidance anyone can provide.
Thanks,
Dan
Thanks,
Dan
