shadowsteve
- Feb 11, 2021
- 265
I searched but didn't find what I was looking for but maybe I'm not searching using the right words.
I have two newly built 4s packs using 280Ah cells. They each have a JBD 150A BMS on them.
I top balanced all the cells to 3.65 until the current draw was negligible.
I have one of the packs hooked up and charging via solar & discharging via 3000w inverter with the RV fireplace as a load. The BMS reports cell voltages as 3.18x and pack @ 12.7v. The pack has not been cycled down yet and this is the first draw on it beyond small tests. I can also use the onboard PD4590 to charge the pack once it's discharged.
How far down should I draw the pack? To the 10v BMS cutoff? Should it then be charged back fully to the 3.65v cell cutoff?
There seems to be a few threads with BMS settings but none are exactly the same. Is there a sticky for the settings that I missed?
I found in my initial small tests that the cells would run up and trigger a charging shutoff with 0.1xxV cell differences. Loading the pack would bring them back in line to 0.005V area.
TIA
TIA
