Just built my second 280Ah 24v battery for my boat. Envision grade B cells with a JK bms. I installed the cells in 1" cutting board material and cuts some handles as this is a heavy battery. There is a piece of 3mm acrylic that makes a lid to protect the cells from anything that might be dropped on it.
I charged up with a 15A 24v charger then swapped over to a bench top supply for the last bit. I let the JK do the balancing with its 2A active balancer. All good and ready to join the other battery in parallel.
