His listing had said he was low on stock for some months I assume he sold out.I noticed that GlobalPower's eBay store is only showing chargers, but is not listing batteries anymore. Anyone happen to have heard what's up?
I bought one of these about 1.5 yr ago, Global power sent me another one due to the low capacity of the 1st. Same story as everyone, both of them badly out of balance. I balanced them, got them pretty good & installed them in the van.
I installed them in the van and recently had one go dead unexpectedly. A capacity test showed one at only 34 ah & one at 60 ah. I'm assuming badly out of balance. So I'm shopping for a BMS that will fit inside. Suggestions? Since these cells may be of dubious quality also, I don't want to throw a lot of money at it, so looking for a good value that will do the job. I'm running 2 in parallel if that matters.I found a battery on ebay, free shipping, 100Ah $299... im going to do a load test on it... should i post a video here?
I don't see any need to top balance. I never take my cells above 3.45 volts anyway. The problem with that is we're not charging the individual cells. If it's anything like the 2 Global Power batteries I have like this, and it looks like it is, you'll have 1 cell hitting the BMS cutoff (way...diysolarforum.com
I use 5 of these batteries, 4 in series in a 48 volt system, and a 5th for the 12volt side of an RV. I have used these pretty steady for a few years. The seller supplied me with passive balancers for each battery and they tested at near capacity once balanced. I would not recommend them as their are much better options now but they have served me well for several years in a low amp draw application (72 amps max continuous but usually under 20 amps )Man, after reading through not the whole thread but only the last 6 or 7 (especially the one demonstrating he was ripped off with fake cells inside), I would not want to waste my time or money on this. Could be a dumpster fire waiting to happen, who knows what other shortcuts or poor workmanship is going on inside? Have you opened it up and thoroughly tested each cell, wiring, etc? Did they use CCA wire? I mean if you have a spare BMS laying around that will fit this application, go for it, but I wouldn't want tospendwaste any more money on one of these.
I have not done a capacity test recently we are using the system continuously right now and it would be rather inconvenient. The device he sent me was a passive balancer that connects to the bms.That's good to know. I contacted the seller to see if he has any of those BMS's. Have you done a capacity test or pulled them down fairly low since then?
Remove the top and manually balance the cells. They are bad about losing balance. The seller was offering add in balance boards for a while, don't know if he still is. I'll pm you his email addressHello all, I bought one of these batteries in March 2022 and it is having issues charging and discharging, it behaves like it has no capacity at all. I've tried reaching out to the seller on ebay for some resolution but I am getting no response. Is there another way to message the company for warranty?
As a last resort, is there a way to salvage the working cells of the battery?
