Yes. Low temp charge cutoff works.Anyone confirmed low temp cutoff on these yet ?
Any update on a replacement ?had one battery suffer complete bms failure today. will not charge or discharge through the bms. Have contacted Jim Gee for warranty. will update with outcome.
What do you mean by 'they all came pretty well balanced'? Were you able to charge them up to 14.4 or 14.6 without the BMS cutting out?so far so good I bought 4 of these for a 48v system .....they all came pretty well balanced .....hooked them up in series and balanced them to my existing rack mounted pack which I also had bought a year ago from global power. No problems they seem to be holding up just fine. My first pack I had to set the charge voltage down to 56.4 on the MPPT controller due to the fact it was fighting with shutting my invertor down since then I have had no problems running it this way. Global power seems to be a good company from what I have seen
Haven't shipped yet, contacted me today, apologized for delay(blamed holidays) and said he would get them right out. Will continue to update.Any update on a replacement ?
I just checked mine and it only charges to 13.8. The AC charger keeps cycling and tries to get it to 13.9 but it won't. Should I try and return it?What do you mean by 'they all came pretty well balanced'? Were you able to charge them up to 14.4 or 14.6 without the BMS cutting out?
According to the document that comes with it, the BMS voltage cutoff is 14.6.Ask for bms specs. Maybe it’s set low.
Should at least get to 14.0-14.2.
Probly has one cell that over-volts and the bms shuts off charging.
Seems to me they have cylindrical cells, IIRC
Thanks for the help. I did contact them earlier, we'll see what he says.I would contact them - seems the bms is cutting off charging. There have been many complaints on this. Maybe they have a fix.
I have a very basic charger, no way to change settings.Or set your charging boost to 13.9V.
13.8V will fully charge a lifepo battery.
I've been close to getting the AIMS 12/24v charger for a while. Will that help?You may need to get a programmable charger. There are some nice ones out there and not too much $$. The victron is good, aims power, or get an inverter/charger combo - depending on your installation.
I haven't seen this with the same charger and my other 12v battery. So the BMS is causing the charger to shut off when it gets to 13.8, and then it starts up again because it's trying to charge to 14.6?There's no way I can charge my prismatic cells at 14.6V - one of the four cells will always reach full charge before the others and over-volt the bms. This gets bantered about all over this forum - charging parameters. The old lead-acid stuff is just too high for lifepo. If the bms is set to cut off at 14.6V and your charger charges to there, it's going to shut off. Imbalanced cells will cause over-volt and bms shutdown. And it's not a good idea to constantly shut down a bms - it should be the last line of defense should your system go haywire. Your charger should not bounce off the bms.
