I asked Bluetti a couple of battery questions. Here they are and the tech’s reply:
Question:
“I was wondering if you could answer a couple of questions regarding your RV5 and it’s support for third-party batteries:
- what functionality would I lose if I use third-party batteries vs Bluetti?
- is there a standard comms protocol the RV5 uses that would still allow the RV5 to communicate with other batteries?
The reason I ask is that I have a couple of Eco-Worthy 48v 100ah server rack batts so wanted to know how well they might function with the RV5. The Eco-Worthy supports CAN bus and is compatible with many other popular inverters.”
Reply:
“The following is the detailed answer to your question.
- Since there is only one temperature sensor connected to RV5 from the third-party battery, for a 12V battery, it needs to be connected in series with 4 12V batteries. Therefore, the temperature sensor can only be connected to one of the batteries and cannot monitor the temperatures of all the batteries.
- RV5 uses a proprietary protocol. Currently, it does not support connecting third-party batteries with BMS boards. The CAN bus protocol of Eco-Worthy may not be able to communicate with RV5, and the battery status (battery level, fault protection) cannot be synchronized, which may lead to the failure or interruption of the charging and discharging path.
- 1C charging and discharging rate limit. If the battery group continuously draws power exceeding 4800W (48V × 100A), it may trigger the overcurrent protection shutdown of RV5.
Therefore, if your Eco-Worthy battery has a BMS board, it will not be compatible with RV5 and cannot be used.
Hope this is helpful.
Have a nice day.
Best regards,
Lois”
