ghostwriter66
"Here - Hold my Beer"
What is bad about the plug and play BMS? What settings actually need to be changed in a BMS? Cycle bandwidth is not controlled by BMS for most systems. What are the downsides of plug and play solar enthusiasts? LiFePO4 cycle bandwidth cut offs are very effective and can pull full capacity and I don't see a reason to change them. Why would you?
Nothing at all is bad ... I have a ton of DALY's that do perfect for what they need to do ... on my personal stuff I like to tinker with settings and be able to control or even micro-manage these devices .... so as i said -- sometimes its great to Plug and Play (set-n-forget as my boss says) ... and then there are times that you specifically need for it to do this or that ... and thus you need a programmable one ...
For BMS's definitely One Size does not fit All ...
