I assume you mean 4S. 4P would only be 20.23V.I don't think I would go 4p on the panels. That is getting too close to 100 volts. The 12 gauge panel wire seems a bit light. I would go at least 10 awg. for the solar panels. Probably 3S3P would be nice for the panels.
I will put 2 additional batteries in series and then in parallel with the others.Your batteries are 4 x 12.8V x 100Ah = 5120Wh x 90% usable = 4608Wh usable. So your batteries are barely enough to last one day. Considering the need to run a CPAP you really want more capacity to be safe.
Yes the combiner box has 15A fuses built inWith 3 solar panel strings in parallel you need to fuse each string. Perhaps your combiner box supports the use of breakers.
Unfortunately I already have 8 panelsWhy use 12 100W panels? Why not use 3 400W panels or 4 300W panels or even 6 200W panels?
I did that wrong. I will change to 200A.Your calculation of the Class T fuse size is incorrect. You need to divide by the 85% inefficiency, not multiply.
3000W / 24V / 85% = 150A. That's for choosing the wire size. The fuse size is then 125% times that value. 150A x 1.25 = 187.5A which means a 200A fuse
Thanks for the link. Once again I already have 2 12V, 100Ah batteries coming and can't stop it.Why not use 3 24V 100Ah batteries instead of 6 12V 100Ah batteries? Avoid the possible issues of having batteries in series. You need a better way to wire the batteries in parallel. You do not want the main positive and negative (to the bus bars) coming off the same series pair. See chapter 3 of Victron's "Wiring Unlimited" book.
Great! So here is what I have come up with, with all the changes. I hope this is closer.The battery wiring looks good.
I wondered about that. So I will add those in. 125A fuse off of each positive terminal. Is there a preference on which type of fuse to use? ANL, T, or something else?With 3 pairs of batteries in parallel you may want to fuse each pair
Ok, I will try to find them. I did find the ANL and they are quite cheap but the T would be better. Thank you so much for all your help.Class T would be an obvious choice to handle each 24V 100Ah LiFePO₄ battery pair
That is a decent price. I will go with them. ThanksI bought my Class T fuse and its holder from Don Rowe:
