Hi all, first time post. I've searched and didn't see an answer.
So I received my Signature Solar EG4 48v battery. Temps in my area have dipped from mid 30s to 5°. I built and insulated box (rack) using 1.5" polyiso for insulation. I've basically duplicated my well house setup using a Thermo-cube, light bulb and remote thermometer to keep the temp above freezing. The cube turns on at 35° off at 45° (actual is 36°-55°). My question is, "Is it good enough to just be above freezing"? I also have a inline thermometer that i can use to set to any temp with any differential and thought about using that. Best operating range? I appreciate your input. Thanks
