Nice
@Brucey didn't think about ship-to-shore stuff. This would probably work just great - and has the added benefit of being intentionally used in outdoor/wet environments, although I could see there being some AHJ inspectors who may not like them...
FWIW, AI said this to me when inquiring about NEC 2023 compatibility for residential applications:
The NEMA SS2-50 connector is a 50A, 125/250V locking connector commonly used in marine and RV applications. It is mentioned as a specialized connector for those uses rather than general residential purposes.
Regarding the 2023 NEC (National Electrical Code), there is limited direct mention of the SS2-50 connector classification. The NEC 2023 has articles for marinas and boatyards (Article 555) which include requirements for shore power and related receptacles, but it does not specifically list or mandate the SS2-50 as a general residential receptacle type. The SS2-50 is recognized as a NEMA standard connector type but is primarily specified for marine/RV environments rather than typical residential electrical distribution.
For residential installation, the NEC typically requires receptacles to comply with the standard NEMA types specified under Article 210 (branch circuits for dwelling units), such as 5-15, 5-20, 14-50, and similar common household and appliance receptacles. The SS2-50 can be UL listed and compliant for certain uses and might be allowed if it meets all code requirements (voltage, current, grounding, GFCI protection if required), but is generally not listed as a standard residential receptacle by NEC.
In summary:
- The SS2-50 connector is recognized for marine and RV use and appears in NEMA standards.
- The 2023 NEC does not explicitly designate SS2-50 for residential receptacle installations.
- Installing an SS2-50 receptacle at a residence might not strictly violate code if it meets all the installation and protection requirements (such as grounding and GFCI where applicable), but it is not a typical or standard residential receptacle type per NEC.
- It is advisable to consult the local authority having jurisdiction (AHJ) for approval since local amendments or interpretations might differ.
References for the SS2-50 spec and related NEC residential receptacle rules come from NEMA standards, NEC Article 210, and NEC Article 555 for marine, along with product datasheets and installation guidelines.
