I finally got my other two strings hooked up.
I have 32 cells from Basen (Emily) from around Feb and 32 from Qishou (Amy) from around May. The posts are not in the same place. The posts on the newer cells are farther apart. Both have "eye" shape posts and qr codes match eve. It doesn't matter for me since they are in separate strings, but that might cause problems for others.
I think it's been brought up before, but I wonder if the Quishou Amy is Luyuan Amy. I was sent photos, etc and the packaging was the same including corner protectors for the new cells. Studs were welded. Date codes are end of April. So far cell voltages haven't diverged at all.
Anyway, so now I have 32 cells with welded studs and 32 cells without. So it will be interesting to see if the banks diverge. So far, it hasn't seemed to matter. I did have one issue where a couple threads of one cell stripped out of one of the older cells. The stud wasn't all the way in. So far, I was able to thread a new stud in using the rest of the threads and it's holding.
My procedure for adding new strings was:
1) top balanced the new cells
2) charge old strings to float via normal charge controller
3) take offline the old strings
4) put online the new strings
5) discharge new strings 10%
6) charge new strings to float via normal charge controller
7) shutoff loads and charging
8) wait for new strings to settle so voltage was close across strings (it was .05 off)
9) put online old strings
10) turn on loads and charging
11) At this point the old strings cell voltages were not as flat as the new cells. So I ran an extra long absorb which means an extra long balance. The cells delta came to .01v
