New gate opener project; off local grid
DocWatt
[Disclaimer: I've searched and cannot find info on this on the site, but please advise if someone knows this has been discussed before.]
I am installing a Ghost Controls operator arm on a new gate I just installed. The system is designed to be AC powered, but they do sell a solar option, however, even they say to upgrade the included 10w panel to a 30w and if you do so...they say to get a deep cycle battery, negating their battery box with two 7ah batteries completely. Nice, right? So basically they sell a "solar looking" set-up that is backed up by AC.
In my project, I do have access to AC, but it's to much of a hassle and I want to try to get this 100% solar, even if it's a bit over-engineered to do it. I've seen a few things Woody has posted on micro solar systems and I feel like that's close to what i'm looking for, but the cold usage complicates a bit (will be used year round, but obviously it's easier in the warmer months).
My plan: I have the Ghost Controls TSS1 (operator arm and control panel only) and I have a Renogy 30W panel. I know I may need a charge controller (suggestions welcome), but the circuit board that comes with the unit will rectify up to 30w so it can serve as the controller for my panel (in theory). The main issue i'm trying to resolve in my non-fully-solar-educated mind is what to do for the battery. I'd prefer to mount it near the panel and operator, so lithium is attractive (mostly because of the weight), but this will always be outside (in some sort of enclosure i'll build...perhaps with some help/suggestions), but while I live in N.C., USA (zone 7B) and it won't be below 10 deg F often, that's below the normally enjoyed "above 32 deg F" charging zone for lithium. I know I can discharge it below that, but i'm guessing that is not a great plan for a winter of use...discharge as needed, recharge only when above freezing.
From what I understand the draw would be around 3-5 amps for the gate operator per cycle, with an additional 4 amps used for five seconds with the lock = 9 amps per activation; 18 amps per full cycle (open and closed). The draw on the operator will of course change a bit as that is estimated, not measured under load with my particular gate (nothing super heavy thankfully). There is also a 25 milliamp continuous draw for the circuit board.
So, do I go overboard and super size the battery AH to cover the inefficient nature of running the system in the cold? (As in have a 500-1000AH battery that can just recharge when it's warm enough and try not to discharge to far between charges.) Should I go just above what I need battery wise and then run a thermostat controlled warmer? Anyone have experience with the Kilovault HLX, LiFePO4 Blue batteries (BMS with built in heaters), or the Winston LiFeYPO4? Should I skip lithium all together and go AGM or gel, which still have some cold issues of their own?
Any guidance and direction to help me avoid spending way to much if there is a better option is appreciated.
Perhaps i'm asking to much, but if someone with experience can lend some aid i'd appreciate it.
Not trying to be an annoying newbie, but am really hoping for some help on this. If there's a simple "just use gel as it doesn't care about the cold" please let me know. I'm just not knowledgeable enough to get what the best options are yet.
Posting the same thing in multiple places doesn't help making people to want to help you.....I think you know the answer to your own question with all the data you presented....
Not trying to be annoying. Had someone suggest I posted it in the wrong place, so I tried another. Sorry if that's against the rules.
If you have a suggestion please make it. I'm not trying to wast time and I seriously have no idea. Rather pointless to post all that if I knew the answer. I'm a newbie. Please be fair.
