Hey guys, I'm new to this forum, and to building off-grid systems. I'm currently trying to help my father build a backup system that would run a water pump (and maybe fridge/freezer) off batteries, in case the grid goes down.
I currently have two questions:
If grid is NOT available, we would like to use the batteries to their full extent.
The reason should be obvious, but: If grid goes down, and the batteries are at, let's say 20%, then they would not be able to power the critical appliances for very long.
Thoughts? (Sorry for some swedish in the image, hopefully it makes sense)
- Would the below setup work? Is there any major safety-concern that anyone can spot? (DC-breaker from PVs?)
- Is there any way you can have different "Low DC cut-off voltage" depending on if grid is available or not?
