Just found out about cascade heat pumps:
In cold temperatures, single stage heat pumps have horrible efficiency and can be near impossible to use during the winter with off-grid solar. The colder it gets, the less efficient they become. Usually when it is cold, sunshine is reduced, making it more problematic.
Different refrigerants work better at different temperatures. Most heat pumps are designed to work best for the majority of temps that people are exposed to, but not really optimized for cold temps specifically.
So this company is using multiple refrigerant loops (and different refrigerants rated for use in different temperatures) in cascade configuration (like putting them in series, or daisy chaining then):
This allows one loop to exchange heat to the next one. This will increase efficiency of the entire system in cold temperatures.
Has anyone here tried these heat pumps? I wonder what the efficiency is with normal temps. Maybe it can switch to single stage heat pump mode instead for the majority of operation. Then switch to cascade heat pump mode when the temp falls to a certain threshold.
With this configuration you have two compressors and two line sets, so perhaps higher chance of mechanical failure with the moving parts over time.
