FilterGuy
Solar Engineering Consultant - EG4 and Consumers
What inverter do you have for the garage? Can you set the low-voltage disconnect?Thank you. Statement is very correct.
Your option might be very good as well. But in my case i already have 2nd and 3rd inverters (smaller low load). i have everything already almost working. I only need at this moment adjustable voltage switch, for on/off variables. With my preferred custom cut off and my custom turn off. All cables also are ready and in the places. In your case i will need extra long cables for relay, as in my case these AC cables are the only one i have here going to garage. There are no other AC cables there.
Also, how long is the run from the battery to the garage inverter?
