murphylawe
Mad Scientist
Howdy Everyone,
I have enjoyed my Solarsaurus Rex, and the Solar Gantry (Pat. Pend), the ability to run A/C and refrigeration on solar power in the desert has been liberating. That said, I have pretty much killed the (8) 12v AGM battery stack over the last 2 years.
So, now that I have a proven design I will be upgrading the stack to lithium. I have been observing the falling prices for 3.2v-280ah cells with interest. I will need 16 of them, so about $4000.
For the same price I can get 6-Teslas (I have a friend)... and nothing on Earth beats the Tesla for performance/price. I have a solution for the BMS, but that is only half of the problem. Additionally I need an inverter that will function within the operating parameters of the Tesla stack (25.2v-18v) most inverters kick at 20v, so you leave a bit behind. Victrons can be programmed to kick at 19, still leaving some, and they are a tad pricey. With an AIMS 4000w I am stuck with the pins...
So, I was just about to commit to an LiFePO4 battery cell order when I ran across this... and my head exploded.
HOLY SMOLY!!! I never even considered it... too busy with other stuff, but now with Fall and the maintenance cycle beginning... Has anyone in this forum built an inverter? How about an inverter/charger? Can I tweak a DIY inverter/charger to operate within the Tesla parameters of 25.2v-18v?
I am not an engineer, or an electrician but I want to build a 5000w inverter/charger... I play with Arduino, with some advice and encouragement I may explore this. I need to be talked into, or out of this insanity.
DIY Cheap 1000W Pure Sine Wave Inverter (12V to 110V/220V)
DIY Cheap 1000W Pure Sine Wave Inverter (12V to 110V/220V): Car batteries for powering you home? Build a low cost 12V to 220V (DC-AC) Pure Sine Wave Inverter from scratch! The project is based on the low cost EGS002 SPWM driver board module. The DIY inverter board can handle up to 1kW (depending...
www.instructables.com
