taxesarewaytoohigh
We are planning an off grid 32 x 42 shed in Wisconsin with an attached part-time passive solar living space (on cement slab) of 615 sq. ft., and have been trying to determine what is the best off-grid solar system for our situation.
We have calculated our power needs to be 7kwh during the day in the summer with a 12000 BTU mini-split for air. In the winter we believe we will need 2.6 kwh per day, not including any heating. We haven’t figured out the heating yet. We love everything about wood heat and have been heating with it for decades… but old age is making it a little less attractive… (well, okay, a lot less attractive.) We are considering in-slab radiant or propane direct vent units or possibly a mini-split. But primarily while still capable of chucking in wood we’ll likely keep chucking in wood.
We don’t plan to live in this house all year so, it will likely be vacant for the harshest part of winter which is generally December, January, and February. The plumbing is designed so that it can be drained in the winter when not in use. However, we can envision several scenarios where this might be used as a full-time, year-round house, and want to plan for that possibility.
I have limited experience with solar but have installed solar on a couple of truck campers so I’m not completely lost, close maybe.
Renogy has a roughly $6500 package (current deal) that is a 2.5 Kwh system with panels and 8-200 AH AGM batteries. This includes a 48V 3500 watt inverter charger and some installation items. This, out of the chute, looks like a reasonable system to this beginner.
My questions:
Is the Renogy system worth looking at?
Does this package have enough horse power to meet the need?
Are AGM batteries the best option based on price for part time use?
Do they need to be stored in heated envelope? Unless building codes say otherwise, we are planning to place the batteries in an insulated room inside of the shed that is open to the apartment; some heat may get in there if the door is open but no heat is planned specifically for the “storage room”. Is that a reasonable set-up?
My understanding is that lithium batteries can be stored in a sub-zero environment as long as they aren’t being charged or discharged. Is this a good idea? I understand that there are definite advantages to lithium, but we have concerns about fire hazards. Perhaps the batteries should be in a separate shed regardless of the type?
I have been reading some of the threads on batteries and finding that I don’t know what a lot of the acronyms mean. Is there any place on the forum that serves as a glossary or cross-reference? For instance, what is an EG4?
Comments are welcome.
My questions:
