Newbie here looking to upgrade my power system in a class-A motorhome. Currently has a factory setup of 12k split phase generator that I want to keep and a Magnum 12v 2800w inverter/charger that drives one side of the split phase system. It is currently powered by 8 FLA batteries.
My goals are to upgrade the battery bank to be able to run everything from battery, including light usage of one of the air conditioners and installing a solar panel array on the roof to be able to be more or less self sufficient. I would like to install a 5k+ 48v inverter/charger or all-in-one with the associated DC-DC converters to charge from the alternator and keep the chassis batteries charged. I will likely move the high draw 12v accessories (hydraulic jack power and slide-out power) to the chassis batteries. I really only use them when the engine is running anyway.
My biggest questions have to do with the AC side of the system: The only 240v appliance is the dryer and I'm ok with not ever running that on inverter, but I would like to maintain the split-phase system since the generator and standard 50-amp plug and transfer switches provide that currently. Which inverter/chargers or all-in-ones would you recommend that will switch the entire split phase system over when plugging in or using the generator? Of those, would they support the rare instance where I want to plug into a 30a outlet, tying both legs of the 240 to one 120v feed? This is the lowest priority; just curious if any of them would support it.
