Just a reality check...
My camper has 1200 watts of panels, a Victron smartsolar controller and a tesla battery module. (I'm probably moving that to Lifepo4 soon but I scored the tesla and it works) Victron BMV712, smart sense and 24/12 converter. I'm happy with Victron, it works and gives me all the nerd factor I want.
My RV takes 50 amp electrical service. I've successfully run both A/Cs and the microwave off of a 30 amp circuit at one RV park, which was surprising. So, if I target that load level, I'm really going to want around 3200Kw of inversion.
I used a cheap 3kw inverter this summer, and it was handy but frustrating. The cooling fan was really loud and I found that I required a soft start on the A/C to actually run it. The surge on startup was too much for the cheapy inverter.
To use a single phase 30 amp circuit, I used an adapter cable the bridges L1 and L2 phases at the power connector. I have same in a 15amp cable.
To use the inverter, I ran a cord from the front of the camper, to the back where the power connector was. This worked but was janky and annoying.
After summer travels, I see my usage and requirements of this going a few ways.
So I have some items to solve.
I see the Multiplus 24/3000/120 as a good solution... but I kinda want a pair. At $1200 each, that's gonna hurt a little. I'd use a pair of 2kw inverters but that'll save like $100. I'm not even sure why they bother to offer the 24/2000/120 version considering the price. I like that the multiplus has built in transfer switching, but only for one phase... Thus wanting a pair to run in parallel, one for each leg of the AC panel. Oddly the 5000w units are nearly 2k, so I see dual 3ks being the way to go.
I could wire up a diy transfer switch, get a second cheap inverter and add soft starts. This would get me there. I feel like it would also affect the resale value of my camper. (Which is an issue when talking about a unit like mine.)
So, do I go with a multiplus or should I be considering something else? I honestly just haven't seen anything else that comes close in features.
- Run a single A/C off solar all day while I'm in transit to keep the camper cooler inside - It can take some time to cool off after towing for 8 hours in 90 degree+ weather.
- Run at least one A/C all day when I'm at the beach, with the option to run two when needed.
- Use the inverter hybrid to prevent killing power when I have a 15 amp circuit.
- Power the fridge to save on propane while driving
- Full power when boondocking.
- No external wiring. One moron thought I was camping in the street when I was visiting my father and had it plugged in.
- Don't care if I can run laundry off solar... It uses a crap ton of water, but it'd be nice as well. (I have a combo that runs off a 15a circuit.)
