davecason
Hi Gang,
I'm building a battery box with a Pelican case and four 272 Ah Baesun Cells ..... So it'll be used for 12v and 120 out more than likely. (still planning it)
Anyway, there a little matter of charging up the cells ...... here's where its confusing, I will want to charge it up when I'm in the truck cruising along of course.
So right there is a basic DC to Dc charger and I'll pull 20 amps out my butt for a range.
So truck alternator in to the DC to DC charger and off in to the BMS and on to the cells, so problem solved right? (grin) No ...... here is my question to you experts, since the BMS is going to sit between cells and literally everything else in and out of the cells, why do people buy DC to DC chargers at all?
I'm guessing that since the LiFePo4 cells will take everything you can toss at them generally, that DC to DC unit is more about protecting the vehicle and the alternator as opposed to saving the cells? Is that it? How big of a difference is a 20A DC to DC charger vs a 40A DC to DC one to for that matter?
So question 2 in with the same thing, I'm also going to add in a 200 watt folding solar panel for the battery box too ...... so same question, I'll get a MPPT charge controller that will match the panel output and add THAT to the mix as well. So question 2 is again - since the BMS is sitting between the cell and both charging types - the DC to DC charging and the MPPT .solar charging .... can I just use a simple Chinese charger to handle the solar side of things?
Lastly do you folks think I should step it up with something like a Victron BlueSolar MPPT 75/15 for the panel and then maybe a Victron Orion-Tr Smart 12/12-18A DC-DC Charger? It's really what quality of bits do I have before everything hits my JK BMS? For that matter what do you folks think of the Renogy 40A DC-DC Battery Charger with MPPT? I could kill two birds with one stone then so to speak?
SO, the two questions why DC to DC and for the panels what charge controller quality / brand please?
Any suggestions, thoughts, or comments are appreciated !
Cheers'
Dave
Cheers'
Dave
