Iceman218
Received 4 CATL 271 3.2 cells from @Michael B Caro last month and finally have some success to post. Per help on the forum, I also purchased a Smart Daly 4s 250 amp BMS and a Progressive Dynamics 45 amp LiFePO4 charger. Still awaiting a wake up button from a link on this site, but other than having to use the charger to wake the BMS once in a while, it is working well.
The issue was the ability to operate a hair dryer and I think you can understand the importance of this item to my relationship with my wife. With my frost damaged 2 6V Flooded cells, I could get three minutes of hair dryer operation. But that was actually suggesting my 1000 watt inverter might not be a road block. Well, with my cells properly top balanced then configured with the BMS, it now operates the hair dryer just fine from any outlet in the camper. So the 1000W inverter that was standard content in my GeoPro may prove to be enough unless I want to operate more. I was of the believe that a 2000 Watt inverter might be needed.
I have 2 100W solar panels and do understand it would take days for the 10 amps they can produce in Michigan to ever charge up a depleted 271 ah battery, at least that now has become my weak link. There is room on the roof for 600 watts and I also plan on getting an EPEVER 30 amp MPPT solar charger (since I only seem to be able to get 5 amps per panel) but welcome your thoughts on this set up.
