fromport
power = amp x volts x power factorIf anyone has the updated firmware on a grid-tie setup + clamp meter, could you please confirm idle power usage with PV disconnected and no charge/discharge activity? I measure 1.09A, which is the same as what was reported earlier in the thread. I'm wondering if newer firmware improves this. GSL support says it "is actually not that high", but the external meter doesn't lie...
240 volt x 1.09 amp would be 261.6 watt if the power factor is 1.
We don't know if that is the case.
I don't have the equipment to measure that.
if the _idle_ powerfactor is 0.5 it would only be 131 watts which would be reasonable imo
