Wow, I am honored! I hope to post many more as our system continues to develop. If there are any specific pics that you want just let me know. I will be more than happy to capture them and post back. Also, if your electrician says something along the lines like "that's not up to code".... LOL, please let me know! I am trying to do a great job on my home solar system, but I am by no means and electrician. So, there may be some issues with what I have done out of 'not knowing what I don't know'.
I have been using Chap GPT for some answers as well... and in discussion with Ian @ Watts and Adam De Lay about the fusing stuff.
In a nutshell, what is 'in the works' or has already been done;
* Siemens 140,000a SPD added to main panel w/ older secondary Eaton SPD left on for additional protection,
* Siemens 140,000v SPD planned for Well House sub panel and Critical Loads Panel
* All solar panel strings will have a Midnite Solar 300v DC SPD
* Ruixu batteries already has a fuse and breaker on each unit
* NHX-12K internal breakers @ DC battery, AC grid, AC loads terminals
* Home Grounding system heavily upgraded from 'ineffective' 55-year-old setup - Added second ground bar 10' away, all new connections, added second 6 gauge run from main panel to 1st ground rod to second ground rod, so dual rods, dual ground wires. Note - Old ground wire was loosely attached to old ground bar on a rusted-out ground clamp.
* DC breaker and Fuses installed at each array in waterproof conduit box
* DC breaker and Midnite Solar DC SPD installed at the inverter shed
* Soft start added to 5-ton AC system (Soft start acts as a sacrificial device), plus it helps the inverter with in-rush surge
* Considering Victron Lynx Power In fuse modification to add a 250A Mega fuse to each battery connection inside the bus bar for added protection
* Still on the fence about the Class T fuse between inverter and battery bank. Lack of access and cost of fuse are key challenges. As I work on system, I will look for a solution to make this possible work in my tiny shed.
I need to look into adding an SPD to the battery bank, but is that Midnite Solar 300v DC unit enough for the entire bank at the inverter?
This weekend will be a huge push as I found a local contractor to trench 300 feet of conduit runs for $450. The trencher would cost me $250 to rent, plus the hassle to pick up, return, washing it and fueling up.... so, the extra $200 for the work is well worth the expense! That being said I will be fully prepped with the wiring for four 4.8kw solar arrays once I get the other 3 array locations wired up! Then I need to build two 'lean to' solar panel patio covers on my rear garage (AKA - The Goat Barn) and one 'Solar Pergola' for the final array. But that trenching is what scares my 53-year-old butt the most.... that back breaking stuff is what really slows me down. I will be extremely happy once the wiring & conduit is done by the end of the weekend!!! I am starting to see the light at the end of the tunnel!
John
