I just got a NinjaBatt 560wh for my boat/camping, and unit will not power on. When I plug in a charger, the display lights up, unit says its charging but is accepting 0watts(so its not charging). When plugged in and "charging", i can run DC outlets, usb, etc but the inverter does not work. Opened the unit up to see if there were any obvious culprits. found none. Things were secured quite well.
Is this a known common problem? has anyone else experienced this with a powerbank? Hoping there is a process to fix this unit.
Much appreciated.
Chris
Much appreciated.
Chris
