GridWorks Green Solar
Solar Innovator
Here is what works project system with three sets of 9 12VDC solar panels series 180VDC, 5amps + 5amps + 5 amps= 15Amps to run 120VAC mini split and more, Four FETs power board 40N65 and 15Amp ISO transformer output transformer, system allows you to add a secondary ISO transformer for 24/7 550+ watts backup secondary power and additional stability/ higher voltage for solar input.
The new two FET inverter is in beta testing 550 watts continuous output, 650 watts is currently the maximum I have seen to date. 700 watts and the FETs failed shorted source to drain, output good sine wave 120VAC 60Hz. Useful power.
Two strings of 7 standard 12VDC solar panels 140VDC, not tested yet parallel in additional groups of seven panels for more watts/amps power.
Can not wait to build the new circuit boards. More soon
