GridWorks Green Solar
Solar Innovator
Think first I will test dual 12VDC inputs to the two FET inverter and test one of the 4 transformers I have that is center tapped on the 12volt inputs the output is 120VAC.
Have been simulating how the Project system will react to disconnecting grid powered ISO transformer in full sun and how it is going to work, Have two voltage controlled relays not doing anything with the outputs monitoring the system output voltage will likely devote one to just removing the latch on the ISO transformer lock out.
Simulation going well
