Is that an AC charger, or 12V (cigarette lighter plug)?
65W is the peak output. Real question is how may watt-hours it draws while running your MacBook for 8 hours (which depends on what applications are running.)
Possible ways to answer this without measurement are, "How long does MacBook run on its internal battery" and "how long to recharge internal battery from 65W adapter".
Remaining question not as easily answered is "How much current draw from 12V battery while powering 65W adapter recharging internal battery". That would either be 12V current draw by a 12V charger or by an inverter powering an AC charger.
I would bet the smallest external battery would be more than enough, e.g. 35 Ah 12V AGM. The 65W adapter will draw about 5A from 12V battery, and 50% DoD of 35 Ah would be 17.5 Ah, 3 hours of charger operation. That's if AGM is recharged in the day and drained at night. Feeding laptop while the sun shines, would last even longer.
Assume 35Ah battery wants 0.2C charge rate, 7A or 84W. A single 100W panel would do that, and could provide 5 hours charging in a summer day, less in winter. Adjusting panel angle to track sun increases hours. Two, 100W panels with an acute 60 degree angle between them would provide flat power throughout the day. Pick an MPPT charger with no more than 10A output (if MPPT voltage is sufficient) and over-paneling with excess PV could be done without charging battery at excessive current. Could use one or more 24V panels.
You can probably use your vehicle battery, just add a PV charger for
You can probably use your vehicle battery, just add a PV charger for it.
yep the laptop is a AC 65 watt charger
