sunshine_eggo
Victron's little biatch
LOL... that's a really nice find.
There is a recommendation for a circuit breaker in the latest version of our V5 manual (V1.5), but it's possible an older version manual was included with your battery packages. Either way, I am working to add more information about this topic in our documentation and integration instructions.
We recommend installing a circuit breaker or disconnect between the battery bank and your inverters. Please start up all of the batteries together as a group, before powering up the inverter, as outlined in the procedure below. This will allow any start up current surge from the inverters to be split equally amongst the batteries. Keep the breaker/disconnect turned off (open circuit) until all the batteries have started and are in standby mode. Once the batteries are turned on and in standby (Run LED blinking green) you can close the breaker/disconnect and then turn on the inverters.
That's very concerning. Your start up procedure is consistent with the Sol-Ark manual. Also, Pytes has published multiple videos, including Sol-Ark videos, showing start up procedure without introducing an external precharge resistor.I just stumbled onto this thread and want to add my experience. I purchased 4 Pyrex v5 batteries in the spring of 2024 for my Victron 10kw inverter system.. After setting it up I noticed one battery that failed to shut down. NAZ solar contacted Pytes and I supplied the same information as the OP. They sent a new power board and I installed it. At that time I was told that I had probably started the system incorrectly and that the inrush to the capacitors of the large inverter was the problem. NAZ insisted that there was a pre-charge resistor in the batteries and I had somehow not started the bank correctly.
A few months later, I had an issue with a second battery not shutting down. At this time I called Pytes directly and they sent me a new power board. I explained what I had been told by NAZ and they responded that currently there is NOT a pre-charge resistor in the battery. my system has 2 500 amp breakers between the batteries and the inverter. I was starting my system with the breakers off. Then starting the batteries and finally turning the breakers on. The inverter was off this whole time. However, an inrush occurs to the capacitors even though the inverter is OFF. That is what damaged the battery power board.
There are a few solutions. I chose to fix the problem by putting a blue sea battery switch and a resistor in the system that bypasses the breakers and allows the capacitors to charge slowly. I now turn on the batteries. Then turn on the blue sea switch allowing pre-charging to occur. And finally turn off the blue sea switch and then turn on the breakers.
There are a few very good videos online showing how to do this with or without a light bulb in the pre-charge circuit. I have had no problems since. Pytes and NAZ both worked with me. I only wish NAZ had gone to Pytes and checked this earlier. Pytes did say they were considering adding a resistor in future builds. I do not know if this has occurred.
In my case it was during original install. With everything off, I began to connect positive lead to bus bar and saw spark. I immediately stopped and investigated, finding voltage ( 52+ ) on master battery. According to Pytes, that spark is what damaged the power board. Of course, now I measure voltage everywhere before hooking anything up.That's very concerning. Your start up procedure is consistent with the Sol-Ark manual. Also, Pytes has published multiple videos, including Sol-Ark videos, showing start up procedure without introducing an external precharge resistor.
How did you notice that one battery failed to shutdown? I've never turned mine off since they were first installed.
So, they're relying on the current limiting capability of the BMS to precharge the inverter capacitors? I would think that four batteries delivering 400 amp should be adequate to charge the capacitors without failing.Wow! That's really interesting! Your experience was almost identical to mine. In my case, however, it was Pytes themselves who insisted I did not start the system correctly - by not having a breaker or disconnect between batteries and inverter(s). That kinda pissed me off. It took me over two weeks and lots of emails to get a new power board. That kinda pissed me off too.
I specifically asked a Product Manager what he suggested as startup procedure when I repaired the battery, as I had followed what was in the user manual and shown in official Pytes V5 video. I was under the assumption the batteries had pre-charge circuitry. His comment:
Like you, I did add a ( Victron ) disconnect switch and purchased a pre-charge resistor. I strongly suggested they remove or edit the youtube videos showing recommended startup and include the above instructions with shipping batteries. I do not believe the young product manager likes me.
These are not cheap batteries. I was disappointed in my experience with Pytes and, frankly, do not trust my batteries at the time of this writing. It's a new install for me and I am monitoring the batteries like a hawk via VRM. Of course, any little oddity in charging or discharging has me wondering if there is an issue with the batteries.
Hello, I am Cris, the manager of product department at PYTES. I sincerely apologize for the inconvenience our service has caused you. I acknowledge that our documentation was not detailed enough, and I see that you’ve spent considerable time researching related materials to clarify the confusion—this was certainly not our intention.Wow! That's really interesting! Your experience was almost identical to mine. In my case, however, it was Pytes themselves who insisted I did not start the system correctly - by not having a breaker or disconnect between batteries and inverter(s). That kinda pissed me off. It took me over two weeks and lots of emails to get a new power board. That kinda pissed me off too.
To address this, we have already added tags to batteries shipped after March, specifying the necessary circuit breakers and pre-charge resistors for installation.
Does this also apply to Sol-Ark inverters?eliminate potential risks caused by inrush currents from Victron inverters' internal capacitors.
