boondocker78
- May 25, 2022
- 7
Help! I have a strange issue happening with my new Renogy inverters and my new SOK 206ah (w/heat & BT) batteries. Appologies for the long post but I wanted to be as thorough as possible.
Initial test with new batteries.
Now comes in the interesting part:
I did the exact same procedure as above with Brand new SOK 206ah battery #2 which was fully charged to BMS cutoff with a totally different result explained below.
At that point I was thinking Battery #2 was fubar, so I charged battery #1 back to bms cutoff to try it again.
Went through the exact same setup process again but with Battery #1 that had previously worked fine. Same result as above where it trips the battery BMS every time you flip the power switch on the inverter.
Ok. So now I think the inverter is at fault. I return the inverter and buy a another of the exact same model. It arrives a couple days later; I pull it out of the box set everything up same as above with Battery #1. Same result, battery BMS gets instantly tripped with inverter power flipped on.
I re-test this half a dozen times with both batteries. I also test it with a cheapo LFP 20ah battery I have, and it also trips the bms on it where I had to wake it up again just like my SOK batteries.
Now then, I think it must be these crappy inverters. So, I return the inverter once more and order a Renogy 2000w this time, thinking maybe a different model will work, it arrives 2 days later, I unbox it, set it up on Battery #1 that is fully charged.
SAME DANG THING HAPPENS.
So I test it again with Battery #2
SAME THING…
At this point I don’t know what to think. So, I grab an old discharged lead acid battery and charge it up as best I can. Connect it to the Renogy 2000w and it works fine! WTF!
I then take a old cheapo 200-watt MSW inverter that I had laying around and connect it to SOK battery #1
IT WORKS FINE!
Now I have a GIANDEL 15OOw PSW inverter ordered that will be here on Friday. I was hoping it was a Renogy issue but I have now found two other users on this board that have the same issues with the SOK 206ah batteries cutting off when the inverter is powered on.
All that being said, if I get the GIANDEL unit in and it does the same thing, I don’t know what to think.
So, I ask the experienced members of the board to throw some wisdom my way. Maybe I am just simply missing something, but this is turning into nothing but insanity.
- Brand New SOK battery #1 – Charged fully to BMS cutoff with NOCO 10 charger
- Brand New Renogy 1000w inverter
- Connected negative cable to battery and inverter
- Pre-charged inverter capacitors w/ 25w 30ohm resistor with positive cable connected to inverter and resistor inline between positive battery cable eyelet and positive battery terminal.
- Checked capacitor voltage at inverter lugs with voltmeter reading ~13.7v
- Connected positive battery cable to inverter lugs, measured voltage at battery and inverter lugs both same ~13.7v
- Turned on the inverter with the power switch
- Plugged in 750w of work lights, battery discharging at a rate of approx. 70 amps. Fully discharge in approx. 3 hours (I did not time it). Discharged all the way to low voltage shut off.
- Fans and battery light come on for approx. 1 sec then beep and the battery BMS gets reset.
- Test the voltage at the inverter and the battery, reads between 4 to 6 volts.
- Remove positive / negative cables from battery terminals
- Use NOCO 10 charger to reset battery BMS.
- Reconnect negative battery cable to battery
- Start the same process over again with same result.
- Tried this half a dozen times
SAME THING…
IT WORKS FINE!
