Dlashbro
I just posted this way down in a Ruixu experiences thread, but I figured I'd repost here to get a little more visibility.
I just received a set of 6 Ruixu heated server rack batteries with the cabinet. Shipped on time and packaged very well as others have mentioned. Install and setup was a breeze. I installed and powered up on Thurday 1/16. Replaced a lead acid bank. I'm running victron Quattro 10kva, mppt 250-100 and a cerbo gx with a 500a smart shunt. I used the victron cable purchased from Ruixu and the system instantly recognized the BMS and let it drive. Overall I'm very pleased.
I do have a couple questions though. I set the voltages for the quattro and mppt as recommended in the battery manual (56 absorbtion and 54.6 float). But when I look in the remote console under the battery>parameters it shows the charge voltage limit as 54.6. Watching the charging pattern the last two days, the bms took the charge up to 54.6 and then went to float. I thought it should go up to 56 to top balance and then drop to float. But, I am new to LiFePo, so not sure if I am carrying my lead acid thought process somewhere I shouldn't. Is this something I need to correct? or is it good to go?
Currently the lowest cell voltage is 3.316 and the highest is 3.325. Is that close enough to balanced? or do we want a much smaller delta there?
I am guessing (from previous threads) step one is a firmware update. I just tried connecting a pc using a victron MK3-usb and an rs485 cable using Ruixu's tool, but it didn't recognize the bms. I ordered a usb-rs485 cable from amazon and will try again when that gets here. I saw on the Ruixu website the last firmware listed was 18...but the firmware file that said heated model was like v10 or so. Not sure which version I should upload once i get the cable sorted out. Is the firmware specific for heated vs non heated? Also, should the Mk3 work for me to plug into the pc? or is that a different connection that what I need?
Thanks for any insight.
Update morning of 1/20: lost power several times this morning with the batteries flashing alarm. That triggers the quattro to shut down even though per the shunt, we still have voltage to the system (53v+). Quattro was showing a low voltage alarm. Was able to power cycle them and get them going again, but still have the alarm led flashing. Anxious to get the firmware updated but not sure how quick I can get the right cable to be able to do that.
