Hello, I have been recently researching and shopping for solar, as expected retail installers are quite expensive so that got me looking for alternatives. I started with SolarWholesale.com and have now branched into general DIY research and trying to educate my self on what it takes to gather the components myself to install and configure a grid tied system that would cover my daily needs with the configuration now, be available during grid down to act as a generator when the power is out, and to add batteries shortly down the line after I get the system operational for backup power and overnight power to get to fully self-sufficient power generation for my home.
I live in the Austin area and my average daily usages varies from 22 to 60kWh depending on the season. average monthly is 1100 and annual for our first year in this new home was 13200.
For this amount of usage I have calculated ~9Kw solar panel system would be needed but was going to go for 10 or 11 just to have overhead and a bit of room for future growth and battery charging capacity.
My first question is around solar panels. I have a couple of leads on used panels in my area, one is from a commercial project that has several First Solar Series 6 Panels for sale FS-6440's these being commercial panels I am curious if they are compatible with residential solar inverters, controllers etc. but I honestly don't know how to tell. Their specs differ quite a lot from a panel designed for grid-tied residential panels...
440 watts
VOC 219.6
ISC 2.55
VMMP 183.6
IMMP 2.37
The other panel that I have an opportunity to by are Aptos DNA-120-mf26-360w.
360 watts
VOC 40.6
ISC 11.24
VMMP 33.8
IMMP 10.66
the very different ratings for these panels makes me think that the first solar likely wont be compatible with a residential system but I really don't know. I guess this would come down to the inverter(s) input capability?
Follow up question would then be assuming either of these panels are compatible what else would I specifically need just a general major component checklist. I am not looking for a full solution just the directions really on where to go for resources to educate myself and begin understanding and documenting what components I need to assemble to make a working system.
I believe I need a hybrid inverter to accomplish my goal, possibly 2 to support a 10Kw+ array but I am confused about which to choose, micro or string, then there are controllers, MPPTs etc. I am not sure which is needed or best to get.
Any help appreciated. Thanks!
440 watts
VOC 219.6
ISC 2.55
VMMP 183.6
IMMP 2.37
360 watts
VOC 40.6
ISC 11.24
VMMP 33.8
IMMP 10.66
