Hi everyone, lurker for a while but now it's time to post my thread and glean recommendations and advice from you that are much more experienced and knowledgeable at this than I am.
About Me
I'm a former software & database developer / "ladder climber" of the healthcare Information Technology realm turned avid DIYer within the home renovation biosphere with experience in all areas of residential systems (foundations to furnishings). I live in a grid-connected home in NC and want to offset or negate my energy bill while also building a battery backup system to run my home if needed during a grid outage. I've dreamed of having a solar system for years and the time has come to make that a reality as best I can. I will not be going into debt for or contracting out any of this project to anyone so I feel this is the right forum to take part in.
Project Specific Information
A friend of mine convinced me to "go in together" and purchase a pallet of off-lease commercial solar panels. I have a good start with the 5Kw PVs but know I will eventually need more. I want to build my system with the plans of scalability as best I can while remaining budget friendly.
I want to run as much of my home from PV + batteries as possible with the ability to run critical loads during grid outages.
I will not feed power to the grid.
My System To Date
(20) 250w polycrystalline solar panels
My Home's Energy Usage
45 Kwh per day average (stay-at-home family, homeschoolers, and wife and I run two home based businesses -- so we're always home using the juice). Estimated PV array needed to fully run the home: 15 Kw.
My Starting Question(s)
1. The all-in-one inverter/charger systems are appealing for their simplicity, but are they a good match for my starting setup and eventual goals vs. buying individual components?
2. Can the all-in-one inverter/charger systems simply connect into my home's panel or do I need to break out my home circuits to a panel that does not exceed the inverter/charger's capacities? For example, my home's dryer, well pump, tankless water heater all exceed the capabilities of the inverter/charger. Do I need to separate them to prevent killing the device or are they "smart enough" to just wire into and feed what they can into my home's power?
About Me
My System To Date
