Hey All,
Thank you for taking the time to look at my post.
I am currently building out a shuttle bus and going to try to not have any propane, but instead use electricity for the oven and stove. Because of this I am looking to build a larger system. I am going to build the solar overtime as this will sit on shore for the most part
The following are things I am looking to have:
-Air Conditioning (mainly on shore)
-Shore power hookup to charge
-solar setup with 800 min watts, I would like more
-large enough inverter (thinking 4000watt or more - oven is 1800 watt, and stove uncertain)
-Have DC setup for majority, most likely 24v as much as possible -- curious how to do this if I use an All in one like the Growatt 3k
Currently have:
-24v to 12v converter (if need)
-2 200amp 24v batteries
I have looked into the All in ones by MPP and Growatt, but I am not certain how they work with DC components as all the videos and thigns I have read have the batteries directly connected and of course none of them have a DC output. My guess is a busbar before it goes into the All-in-one which then connects to the 24v->12 convert and the 24v fuse box
My other concern is that I will have 10k watts of power and what All-in-one with a high enough PV input (800watt min) and AC output (3000watt or more min) could even work without being gigantic, expensive, or noisy as hell. I am beginning to think I need to build my own system, but double checking here with you all
Thank you all for your time and help, I so appreciate it!
Currently have:
