Hi, I've been running lead acid golf cart batteries for 15 years and am almost ready to switch to lifepo4.
I have 16 314ah Eve cells that just arrived from luyuan, along with a 200 amp jk bms with 2amp active balance.
I am in northern Minnesota and don't have any heated out buildings, so I plan to install the batteries in a utility room in my house.
I have been using cheap DC circuit breakers from Amazon, but reading that I should get something better.
I will be running a 3000 watt 48 volt inverter to power my house.
I am looking at a Blue Sea Systems 5191 Fuse Block Terminal with a 75 amp fuse between the batteries and the inverter.
Is that a good choice? I'm looking to keep my costs down, but also want to be as safe as possible.
Would I use the same fuses between the charge controllers and the solar panels, and the charge controllers and the batteries?
I currently have 2 60 amp charge controllers and 1000 watts of solar panels for my 12 volt system. I plan on adding 2000 watts of solar panels soon.
(The wife wants more power
I have never had a shunt, but am told I should get one. Is this AiLi Battery Monitor an appropriate shunt?
I currently have my 12 volt system wired with 4 gauge copper wire. Can I safely hook everything up with that? The batteries will be about 15 feet from the solar panels.
Thank you
Thank you
