I just ordered from CaTL (8) 3.2 volt 310AH cells. My current vehicle configuration is two 100ah AGM batteries underneath the VAN and a Xantrex Prowatt 2000 inverter tied into a Go Power three way transfer Switch. I also have a 100watt Amp Solar panel with a 30amp controller. I also have a 2800 Onan microlite generator underneath the Van which it's source is the gas tank which I like. My refrigerators are drawing less than 4 amps @ 12v so the current setup works great I never really had a problem on any of my trips. The inverter handles coffee maker and microwave without firing up generator.
The A/C is what I really need in Stealth Mode. The Generator is two loud for night use.
My new Coleman Mach 2 NDQ soft start will only draw 11amps @ 120 on high cool about 9 amps in low cool where I would most likely keep it. I was thinking about leaving the AGM's the way they are.
Installing the 8 cells in the RV I have a location that's well ventilated and getting a 3000w inverter replacing the 2000 watt xantrex.
Do I wire them in 8S 24V? purchase a Aims 24v 100amp Charger so I can run off generator/shore power? I guess I would need a BMS rated for at least 150amps with 8 leads for balancing and freezing protection? When the Van is running I would also need a 60amp DC to DC charger?
If anyone can give some ideas I would be grateful a bit overwhelming.
Thanks Noel
Thanks Noel
